Corsair Air 740 with Corsair Lighting Node Pro
Zepher
[H]ipster Replacement
I purchased the Lighting Node Pro the other day so that I could easily change the lighting color, effects, or turn off the lights in my case.
Install was pretty simple, the LED strips have magnets in them so they can be easily mounted and moved if you have a steel case, also has double sided tape so you can adhere them to the case if you need to, then just plug the lights together, run a cable to the control box, then run a cable from the box to a USB header and you are good to go.
Just load up the Corsair software and play with the settings.
I set the lights to a police style, lol.
p_monks33
Looks cool, how are you liking the Air 740, saw one at microcenter, and thought about picking it up.
