Nice job Shaggy. Can't do much better with the wiring, but there is plenty of open pathway there for good air movement. Your second pic is a good case for a modular psu.
Antec did a good job of keeping this case compact but sacrificed wiring capability.
The V2 of the 900 should be a tad wider to allow wire hiding behind the cages. If they did that, this case would be the best. Nothing beats the helicopter blade up top....
Shaggy I am using a Corsair Hx520 in a Lian Li casing with the PSu positioning absolutely the same as yours. But I have placed it in an original position, i.e the fan facing downwards. I have an inch of clearance between the case floor and the PSU fan and under load my PSU gets pretty warm. How does your setup work, did it get hot when the fan faced downwards?
