My gf has a Sony desktop VGC-RA716GY and running WIndows Media Center. She restarted her PC and this message came up on the boot screen,
"\WINDOWS\SYSTEM32\CONFIG\SYSTEM is corrupt or missing. Insert the boot cd and press R to repair it" First of all, this system did not come with any recovery disk so i had to borrow Windows MCE 2005. As soon as it loaded, there were only 2 options. To either delete or create a partition. So what happened to the "repair" option? Should i use a different cd, maybe a regular XP? Would that make a difference? I wouldn't want to do a fresh format since she has a lot of saved files on the HD. If you come across this problem or have an idea on how to fix it, then i need your help desperately. Thanks.
