I had a problem copying anything(text, files, etc.) and then pasting it. It was like it would retain the info for 1 second and then lose it. So unless I was able to copy/paste within 1 second, it would do nothing.
The reason this is happening seems to be Offline Files and it constantly taking snapshots. I think SP2 enables it automatically. The resolution is to disable offline files by opening windows explorer and go to Tools->Folder Options->Offline Files, and unchecking the "Enable Offline File" box. After that go to Tools->Synchronize, and not only uncheck, but remove everything possible from that list. Once you reboot the problem should be solved. This is what did it for me anyways.
