So got a chance to upload shots of the new vid card cooler. I got this since my stock cooler on my Powercolor HD4850 was not particularly a great cooler but more so, it was loud as a jet engine (at least to me). ATI Catalyst helped in making it quieter but I just did not like the cooler. Though my vid card is a 4850, it is a non reference design so smaller (actually I got it because of the size, as well as the price). So most coolers were too big. The Zalman would be a good size but it was expensive for the performance. So I decided to try the Coolink GFXChilla. It had great reviews and seemed to work well on the 4850 reference cards. However, it was not guaranteed to work with non standard designs. I checked my card measurements and did not see too much that would get in the way so I decided to try it out on a risk. Boy am I glad I did.
Anyway, here is the cooler. It comes with the cooler itself, 2 low profile fans (why blue? ) and a bunch of heat sinks including a few low profile ones for the vid ram that are below the cooling pipes, and some thermal paste that I did not use.
So here is the vid card, a Powercolor 4850, non reference design with some stupid heatsink.
Took the old cooler off. Good riddance!
Took off the original heat sinks on some of the VRAM that would be below the cooling pipes.
Also cleaned the surfaces using ArctiClean.
Attached the GFXChilla using Arctic Silver Ceramique. Also attached some low profile heat sinks that came with the cooler on the VRAM below the cooling pipes. It attached without any problems to my Powercolor non standard card.
Put it back in and attached the fan cable to the fan controller. The low profile of the cooler is nice and it sure looks better than my old cooler.
This cooler ROCKS and it keeps the card at around 38C idle and about 49 - 51C after several runs of 3DMark06, which is much cooler than the original cooler. And its SOOOOOO much quieter.
So if anyone has one of these non reference sized Powercolor 4850s and can't stand the stock cooler like me, then the GFXChilla seems to fit it ok.
Well thats about it.
