Hi everyone. I'm finally upgrading my crappy un-overclockable rig, to something I hope will be greatly OC'able:
I'm getting the Core 2 Duo E6600, Crucial Ballistic 2x1 Gig 800 MHz RAM, & the A-bit AB9 QuadGT mobo. It will sit in the Antec 900 series case.
Problem is, I cannot predict what kind of cooler will fit in there. It normally wouldn't be an issue, but I use a fan on the side of the case for extra cooling.
My number one option right now is the Thermalright SI-128 just for it's good overall cooling qualities, but is there something else I should look at instead? Or is that a good choice (I'll be putting a Sycthe 120mm fan on it). Do you think it will fit OK?
