scharfshutze009
- May 22, 2010
I want to convert the Journal Bash Shell Script my professor told me I could continue using after graduation or whatever to Microsoft Visual Basic or whatever scripting language Windows uses for documentation purposes. The problem is that I'm not sure if the commands I choose are compatible or equivalent, so I don't know if the script will do what I think it might do because I haven't test it. Also I need to make a list of the commands or options in the script to help remember how to use it, but that's another problem. What's keeping me from doing this is that I don't have a working windows system with me at all times or often enough to test it on because I'm running Ubuntu Linux on my Laptop PC and my Mac Book Pro is having issues with both Mac OS X and Windows 7 being used through boot camp. Therefore, I can only use wine in Linux to test it, so I don't know if I'll get the desired results I'm looking for. Can anyone help me with testing or figuring this out, so I can take my professors brilliant script and use it to document on Windows because I have no problem using the script in Mac OS X except that I can't use aliases and I have to be root to run it. I will post the code I have for the original script in a reply next.
