Converting internal to external blu ray, is this going to work fine?
StoneTZ
Under the Man's Thumb...waaaaaa!
Looking at this drive http://www.newegg.com/Product/Product.aspx?Item=N82E16827136181
And this external case http://www.newegg.com/Product/Product.aspx?Item=N82E16817392031
or possibly this one http://www.newegg.com/Product/Product.aspx?Item=N82E16817145063
Obviously the first one has esata the 2nd doesn't, I'm debating if that would be an issue with blu ray, thinking I don't need it.
USB 2.0 should be plenty fast.
Does anyone see any problems or have any suggestions for this? It looks good to me but I want to make sure I didn't make any stupid mistakes before I send off the cash.
Thanks guys!
I can attest to the Vantec as I have my BD drive in one. Works beautifully on both SATA and USB.
