Tawnos
- Sep 9, 2001
The vBulletin importer script did not properly handle or import the PMs from our UBB Classic 6.5 board. Finding no definitive answers online, I decided to "roll my own" solution in Ruby, giving me something to figure out in a language I haven't used much (beyond a bit of rails).
Being new to Ruby, I decided to edge in slowly. I needed some way to parse usernames and associated numbers, both on the old and new board. To that end, I did the following:
Not the prettiest, two separate programs to do what could be done in one, a line or two that are extraneous... but hey, learning, right?
Now, I had to get all import userids and associate them with a name. To that end, I ran the following in the members directory. Afterwards, I just did a find and replace to get rid of the leading 0's (which, I learned later, could have been done with a simple .to_i)
Then, the meat and bones of my application, parsing PMs from UBB into something which can be inserted into the vBulletin tables.
Some of it's quite ugly, but it's producing insert statements that work as intended, so I'm okay with that:
Now, I know the following is *EXTREMELY* insecure, as ANYTHING can be executed versus the server... but I need something from which I can copy the text of the created files and run server side (no ssh access, and the vbulletin text field won't accept multiple thousand lines of post. This code simply connects to the database and executes what I paste into it (Thanks to for the idea/help:
Hope that works, will do a couple tests before running the big queries...never used PHP before.
Finally, my SQL question:
I have all these PMs in the pmtext database, will this SQL query work to add them to the "pm" database:
Thanks for reading this far, hope this helps anyone else needing to make the move from UBB to vBull where the PM importer doesn't work, and thanks to those who answer my question .
Code:
File.open("vb_ubb_fixedids.txt", "w") do |outfile|
File.open("vb_ubb_userid_importuserid.txt", "r") do |infile|
while $. != 3427
line = infile.gets.split('|')
outfile.puts line[0].chop + "|" + line[0]
end
end
end
File.open("vb_sorted.txt", "w") do |outfile|
File.open("vb_ubb_fixedids.txt", "r") do |infile|
array = infile.readlines.sort
array.each {|out| outfile.puts out}
end
end
Code:
File.open("ubb_usernames_numbers.txt", "w") do |outfile|
Dir["*.cgi"].each do |infilename|
File.open(infilename, "r") do |infile|
outfile.puts infilename.slice(0,8) + "|" + infile.readlines[15]
end
end
end
Code:
def read_segment(totalpms,segname,infile)
retArray = Array.new(totalpms)
until (line = infile.gets).strip.eql?(");")
qpairs = line.split(/(=>)/)
next if qpairs[0].chomp.eql?(segname) || qpairs[0].strip.eql?("")
left = qpairs[0].split(/q+?(\W+?)(.*)(\1)/).at(2).to_s
right = qpairs[2].split(/q+?(\W+?)(.*)(\1)/).at(2).to_s
retArray[left.to_i] = right
end
retArray
end
numbers = Array.new(5235)
names = Array.new(5235)
totalpms = -1
File.open("/home/tawnos/workspace/pm_importer/vb_ubb_fixedids.txt","r") do |infile|
infile.each do |line|
linearray = line.split("|")
numbers[linearray[0].to_i] = linearray[1].to_i
end
end
File.open("/home/tawnos/workspace/pm_importer/ubb_usernames_numbers.txt","r") do |infile|
names[linearray[0].to_i] = linearray[1]
end
end
Dir["*.cgi"].each do |filename|
File.open(filename,"r") do |infile|
next if qpairs[0].chomp.eql?("%pm_topic_data = (") || qpairs[0].strip.eql?("")
if left.eql?("from")
puts numbers[right.to_i]
puts names[right.to_i]
end
if left.eql?("to")
end
if left.to_s.eql?("replies")
totalpms = right.to_i + 1
end
if left.to_s.eql?("subject")
subject = right
end
end # until
puts totalpms
pm_date = read_segment(totalpms,"%pm_date = (",infile)
pm_time = read_segment(totalpms,"%pm_time = (",infile)
pm_post = read_segment(totalpms,"%pm_post = (",infile)
pm_to = read_segment(totalpms,"%pm_to = (",infile)
pm_from = read_segment(totalpms,"%pm_from = (",infile)
pm_icon = read_segment(totalpms,"%pm_icon = (",infile)
pm_signature = read_segment(totalpms,"%pm_signature = (",infile)
File.open("testinsert.txt","a") do |outfile|
outfile.puts "INSERT INTO pmtext(fromuserid,fromusername,title,"
outfile.puts "message,touserarray,iconid,dateline,showsignature,allowsmilie,importpmid) "
outfile.puts "VALUES"
totalpms.times do |i|
pm_date[i].scan(/(\w+)-(\w+)-(\w+)/) {|month,day,year| pm_date[i] = year << "-" << month << "-" << day }
if pm_time[i].split(" ")[1].strip.eql?("PM") && !pm_time[i].split(" ")[0].split(":")[0].strip.eql?("12")
pm_time[i] = pm_time[i].split(" ")[0]
puts pm_time[i].split(":")[0].to_i + 12
pm_time[i] = (pm_time[i].split(":")[0].to_i + 12).to_s << ":" << pm_time[i].split(":")[1].to_i.to_s
end
time = Time.parse(pm_date[i].to_s << " " << pm_time[i]).to_i
outfile.puts "("
# fromuserid
outfile.puts "'" << numbers[pm_from[i].to_i].to_s.chomp << "',"
#fromusername
outfile.puts "'" << names[pm_from[i].to_i].to_s.chomp << "',"
#title
outfile.puts "'" << subject.gsub(/[']/,'\\\\\'').chomp << "',"
#message
outfile.puts "'" << pm_post[i].to_s.gsub(/[']/,'\\\\\'').chomp << "',"
#touserarray
outfile.puts pm_to[i].to_s.chomp << ","
#iconid
outfile.puts pm_icon[i].to_s.chomp << ","
#dateline
outfile.puts time.to_s << ","
#showsignature
if pm_signature[i].to_s.chomp.eql?("yes")
outfile.puts "1,"
else
outfile.puts "0,"
end
#allowsmilie
outfile.puts "1,"
#importpmid
outfile.puts filename.slice(0,8).to_s.to_i + i
if i == totalpms-1
outfile.puts ")"
else
outfile.puts "),"
end
end
outfile.puts ";"
end
end
end
PHP:
// If the form has been submitted
if(isset($_POST['query']))
// Set Mysql Variables
$host = 'localhost';
$user = 'root';
$pass = '';
$db = 'ex';
$table = 'comment';
// Set global variables to easier names
$command = $_GET['command'];
// Connect to Mysql, select the correct database, and run teh query which adds the data gathered from the form into the database
mysql_connect($host,$user,$pass) or die(mysql_error());
mysql_select_db($db) or die(mysql_error());
mysql_query($command) or die(mysql_error());
else
// If the form has not been submitted, display it!
<form method='POST' action='<? echo'$PHP_SELF'; ?>'>
Name : <input type='text' name='uname'><br><br>
Comment : <input type='text' name='command'><br><br>
<input type='hidden' name='query' value='set'>
<input type='submit' value='Post your comment'>
</form>
Code:
INSERT INTO pm (pmtextid,userid,importpmid) SELECT pmtextid,touserarray,importpmid FROM pmtext WHERE importpmid > 0
