Contemplating upgrade
Kalakaka
I currently have a Sapphire Radeon HD 4850 Toxic video card. I recently upgraded from a 17 lcd monitor to a Dell 2209WA 22 inch lcd monitor. I'm wondering if an upgrade to a GTX 260 would be worth it. Any thoughts? Thanks.
jctazzy
IIRC, GA-P35-DS3L only has one PCI-E x16 slot so the extra 4850 wouldn't work so well.
The 2209WA is only 1680x1050. Are you lagging in something you're playing?
Kalakaka
I started playing Oblivion and I noticed some lagging. I have the latest drivers. I figured the extra ram of the GTX 260 would help.
Brewko
I know you can pick up a cheap GTX 260 core 192 for 130.00 dollars on quite a few forums. That would work great with your 22" Monitor
