Connecting to USB Data storage device over wired or wireless connection at the same time?
Discussion in 'SSDs & Data Storage' started by nekrosoft13, Mar 7, 2019.
  1. nekrosoft13
    nekrosoft13 [H]ard|Gawd
    1,450
    Jan 4, 2005
    We have these devices that can store data to USB device (hard drive or Flash drive), is there an USB device that I can access over WiFI or wired connection at the same time while the USB device is plugged and being used.
  2. EniGmA1987
    EniGmA1987 Limp Gawd
    152
    May 2, 2017
    just share the drive.
  3. Dodge245
    Dodge245 Limp Gawd
    158
    Oct 8, 2018
    Yea pretty much either share the drive or use, \\computername\driveletter$
  4. nekrosoft13
    1,450
    Jan 4, 2005
    its not a PC, its an industrial Automated screwdriver that saves torque graphs for every screw it inserts. It runs some sort of proprietary OS.
    If it was a PC, it would be easy.
  5. westrock2000
    westrock2000 [H]ardForum Junkie
    8,903
    Jun 3, 2005
    I *think* that there is some software for Raspberry Pi's that allow you to plus a USB cable into the PI and and into a computer and the PI acts as a USB "device" to the computer. But then you can also still log into the PI through SMB from other computers to access the storage on the PI. I didn't look too far in to it, and it sound like the software out there was "beta" at best.
    Search for "raspberry pi USB OTG mass storage"
  6. nekrosoft13
    1,450
    Jan 4, 2005
    thanks, sounds like what I need, hopefully it works.
