Kettchxxii
- Jun 13, 2007
So I need a serial connection to communicate with my 'new' powerconnect switch. My primary PCs do not have serial ports currently, although looking at my manual I see I do have one internally. Looks like monoprice has Serial to Ethernet cables for 65 cents each.
Would a USB to Serial connector work for the connection that I will need to access the switch or should I hunt down a bracket for my internal COM1 port and use that?
Either PC -> USB -> Serial -> RJ-45 -> Serial -> Switch
Or [find or buy the damn internal cable] Serial to RJ45 to Serial.
Anyone sitting on a internal header COM1 to external DB9 bracket?
