ElevenFingers
- May 30, 2008
Hi,
Bit of a first world problem here and I think I know the answer, but I just wanted to double check.
Can I connect the Front Panel USB-C Gen 2x1 (10gbps) of a case like the H7 Flow to a USB-C Gen 2x2 (20gbps) header like on the Gigabyte X670 Aorus Elite AX or MSI Pro X670-P WIFI? I understand it would be throttled to 10gbps, I'm just curious if they're compatible. The two motherboards do not have specific Gen 2x1 headers afaik.
Thanks
Thanks
