connecting a bolt-on cpu watercooler to a gpu
fersher
hi.
i am about to build a new computer, and a was wondering if its posible to connect a cpu watercooler like a corsair h90 to a gpu. im thinking that i would need a watercooler with the pump built in to the radiator. something like this.
seems like to me that i would be able to dissconnect the cpu block and connect it to a graphics card with a water cooling block. like this EVGA hydro copper.
would this be possible? and any recommendations on which cooler i should get?
King Icewind
You need a shim for the 7950, 7970/280x. This one should work. Make sure you put thermal paste on both sides!
