Hi all,
I'd like to seek your help in configuring our "core" Cisco SG300 switches to prevent flooding/broadcast storms from taking down the network. I know these are entry grade switches for most of you but this is a big step up from our 10/100 unmanaged switches
Our basic layout is the following:
Internet <--> Router/Firewall <--> SG300 <--> Servers, APs and other 2 SG300s <--> all other unmanaged switches
Configuration is very minimal with the exception of a few VLANs setup for wifi users and unifi (thanks to the people on this forum for helping me out with that!). The entirety of the network is on the untagged VLAN and only some of the SSIDs are on separated tagged VLANs.
What will I need to configure in our 3 SG300s so that the flooding/storms become localized and will be easier to track down based on which group loses connectivity? As it is, my entire network goes down and I'm not quite sure where to start troubleshooting because all the ports are down and nothing short of manual port trial and error will work.
Last week it was users randomly plugging in ports that caused a loop. This week it was an old router used as a print server that magically had its DHCP turn on and froze the network. Looking to put a stop to this. If only one port on any of the switches lost connection, I'd easily have been able to track down the offending device after a 10 minute troubleshoot.
Thanks!
Thanks!
