So basically you want a separate VLAN between your router and switch and then another VLAN for your computers that is separate from the VLAN from switch to router?
What router is this?
Do you have access to the router? Trying to understand what the goal is here, if you just want to PC's on the same VLAN you'd have to configure the link between the switch and the router as a trunk, also the Gateway defined on the PC's needs to be configured on the router as well, you can create a sub-interface with the GW address on the router and that should do it.
What model is the FGT? Let me also ask f it is a smaller model is it in switch or interface mode?how ?
to link between the switch and the router as a trunk ?
When you log in to the webui look under network > interfaces do you see 4 interfaces named wan1, wan2, dmz and internal or something else?its FGT60E
