My problem is this, I turn on my computer and it posts. etc runs to windows and I can do w/e. When I go to bios to turn on integrated graphics (Note I am running off of the 6670) with the 6550d and set the VMA Buffer to 2GB (Because that's how big the card is) I save the settings and guess what? It wont post... I reset bios and it works just fine again. Only thing is, I only have the 6670 working.. With AMD you HAVE to enable the integrated graphics from the bios so that AMD Catalyst will even recognize the second card.. Please help??? I have no idea what is going on..
So this is my set up:
MOTHERBOARD- ASUS F1a75-m pro ( uefi bios with ez mode, epu and tpu on board switches, and all the bells and whistles for your overclocking needs )
CPU- AMD Llano a8-3870k UNLOCKED ( quad core 3.0ghz stock )
CPU COOLER- Swiftech polaris 120 w/ 120mm "Hydraumatic" fan it has 5-direct contact copper pipes
SSD ( solid state drive )- Kingston Hyper X 90Gb sata 3 6gb/s ( windows 7 ultimate 64bit pre-installed and used as primary boot drive )
HDD- Samsung Spinpoint F3 1Tb 7200 rpm ( set up as storage )
OPTICAL DRIVE-> LG Black 10x BD-ROM 3D playback and M-disc support
RAM- G.Skill ARES series 8 Gb ( 2x4 Gb ) 1866mhz speed stock ( these sticks accent the blue color of the ASUS board and are low profile in order to accommodate the behemoth of a cooler the polaris 120 is, the clearance space is ridiculous )
GPU- Diamond 6670 Radeon HD 2 Gb 128-bit memory lane and sports a GDDR3 memory note that this is dual graphics enabled meaning that the single 6670 discrete graphic card is used in conjunction ( I didn't use the word "crossfire" because it's not ) with the integrated graphics on the cpu die ( notice that it has GDDR3 memory and not the faster GDDR5 memory this is because when dual graphics is enabled it converts GDDR5 memory into GDDR3, thus defeating the purpose of getting that specific memory spec since this desktop is dual graphics enabled and ready )
POWER SUPPLY- Raidmax RX-600AF 600 watt power supply and is 80 plus bronze certified
Now Dual graphics is what AMD calls the use of the 6670 with the 6550d integrated graphics , I have enabled it myself but haven't overclocked ANYTHING. 6670 is the highest this cpu will "dual graphics" with.
