Composition Ncase m1 for silent gaming and hobbymining
Bullz
Hello, would like to put together a ncase for gaming and would like to try hobby mäßig bit minen out of attraction to the thing. Important it should be quiet. Would like but at the same time not miss the portability of a MiniITX system.
Goal: price performance. Currently trying to get a 3060 ti for max 470 euro. If I have this there I buy the remaining components.
So I would like to build the system together.
Cheap assembly
https://geizhals.at/?cat=WL-1681706
Compilation:
CPU 5600x
CPU cooler Noctua C14S
GPU 3060 TI ( the one I get deshroud I would do if it would do any good and I can rebuild it back)
Ram 16 GB Corsair Vengeance LPX CMK16GX4M2D3600C18
Any 2 TB M.2 SSD https://geizhals.at/corsair-force-series-mp510-1-92tb-cssd-f1920gbmp510-a1907873.html?hloc=at
Mainboard ASRock B550M-ITX/a 121 euro very cheap or cheap junk ?
PSU Corsair SF600
Fans: 4x NF-A12X25's 2x NF-A12X15's 1X NF-A9X25 !!! Buttom (2 slots 42mm 2xNF-A12x25 or 2.5 slot 50mm NF-A12X15)) !!!
Dust filter NCASE M1 - Bottom
Dust filter NCASE M1 - Top
Dust filter NCASE M1 - Side
Dust filter NCASE M1 - Rear
1.) Would also like to use dust filters in all positions where they make sense ? If a fan blows out, you don't need a dust filter at this position or ? Then only the one at the top position would make sense for me or ? In the upper link he uses top and rear filters.
2.) Should I change any component. Can I somehow get an optimization.
3.) When assembling I then only need a typewriter ? Would not like to start on day X with before friends to build up to notice that a little thing is missing.
thanks
Translated with www.DeepL.com/Translator (free version)
Bullz
Hello,
1.) Just got ncase v6.1 and i forgot to buy the following
ASUS TUF RTX 3090/3080
Low profile PCIe power adapters must be used
Where can i get something like this which has a certain quality and doesn't burn down and is best to order now ? ;)
2.) Mainboard is a Gigabyte B550I Aorus Pro AX. Do I have to buy any other adapters for the connection of front I/O ? I have never done this before. Hope yet that everything is included for this ?
Bullz
Hi,
I have a B550I AORUS PRO AX (rev. 1.0) and would like to undervolt my 5600x with Curve Optimizer.
Bios on manufacturer homepage and the current BIOS I have on my computer
https://www.gigabyte.com/at/Motherboard/B550I-AORUS-PRO-AX-rev-10/support#support-dl-bios
Max stable Bios Fersion F12 with AMD AGESA ComboV2 1.1.0.0 D
A newer Bios version on the net
https://www.tweaktownforum.com/foru...-gigabyte-latest-beta-bios/page891#post977322
B550 Series....F13a with Agesa 1.2.0.0 Date 01/27/2021
Will yet several itx users have my motherboard. With the current there Curve Optimizer settings or I do not find them on. Also possible ^^. If I install this F13a could that then show up or can such non-stable versions make my Pc unstable ? Then I would wait.
