I've reciently replaced most of my workstation's components due to dammage and now i've got all the rma'd parts comming back my way and I'm gonna build a second computer that I'll use as a file server, once i can afford some decient drives. Untill then I'd like to explore the ghetto side of HTPC. I'm gonna load up mce, get a remote and/or wireless mouse/keyboard and giv'r.
I just got a new tv, Toshiba 32" Flatscreen. Its not HD and only supports 480i, which is a bit of a same but it was cheap. Anyway, i was wondering if there would be a diffrence using component over svideo. Frankly, i'd rather use svideo since it'll be cheaper to get a svideo switch box over a component one. But if theres a noticible diffrence then i'll go with component.
If so, i'm gonna need a new video card probably. I dont think my ti4200 supports dvi->component like ati cards do, infact i dont think very many nvidia cards do. Regardless of my desire to keep it cheap, i'd rather not buy a new Ati card thats not as good as my ti42 so i assume the 9550 and 9600np are out. Is a 9600pro up to the task or would i have to go 9600XT?
Thanks for your help
