Hi all
Complicated port forward question here.
I have the following setup:
Paradyne (also known as Zhone) 6212-I3 ---> Linksys WRT54GR
The IP for the Paradyne is 192.168.254.254 with subnet mask 255.255.255.0
The IP for the Linksys is 192.168.254.2 with subnet mask 255.255.255.128
So my computers connected using the following criteria:
ip: 192.168.254.xxx
subnet mask: 255.255.255.128
gateway: 192.168.254.2
dns: 192.168.254.254
I Windows Home Server setup on computer 192.168.254.125 and I want to forward port 8080 to it so I can access from outside.
I have tried setting 192.168.254.2 as DMZ on Zhone and then 192.168.254.125 as DMZ on Linksys
I tried setting DMZ on Zhone straight to 192.168.254.125 (didnt expect that to work, different subnet masks)
I tried port forward of 8080 on Zhone to 192.168.254.2 and then port forward to WHS 192.168.254.125 on the Linksys
I tried port forward of 8080 on Zhone to 192.168.254.2 and then DMZ 192.168.254.125 on the Linksys
None of the above worked. I am at a loss.
ip: 192.168.254.xxx
