Comparison of mining on AMD Fury X vs mining on 1080TI with nicehash.
Nebell
What driver version? what card? What clocks? What miner?
I can't even watch a YouTube video on mine while mining with nice hash.
I always run latest drivers. Using Zec miner but I have both dual and single mined with Claymore for 2-3 weeks with no issues. Also tried Nicehash out of curiousity (I don't like it) and didn't experience any lag.
pclausen
Are you running latest Windows 10 Creator?
I too have issues doing regular tasks while nicehash is running on a pair of 980Ti's.
Archaea
My v7 riser extensions came in from minerparts on amazon storefront
https://www.amazon.com/sp?_encoding...119436&seller=A3EIBTCUXVFG5S&tab=&vasStoreID=
Glad to see the 1X riser extension (V7) gives me full bandwidth for the 3rd 1080TI.
After I let this run for a while, I'll try adding a fourth card. I've got a 1000 watt Corsair PSU. Figure 500 watts for these - I can add maybe one of my Fury X back into the mix. Perhaps even use it as my main display card so I can mine and watch youtube vids at the same time. (wouldn't that be novel?) Those four cards will probably tax out my 1000 watt PSU to 80% ish.
pclausen
I resolved my poor desktop performance 100% by doing the following:
1. Take 980Ti's out of SLI
2. Remove SLI bridge
3. Upgrade to driver 384.76
Not sure if any one of the above in particular, resolved the issue, but I can't even tell that NiceHash is running now.
refraxion
Is Nicehash the way to go? Is it better than just mining ethereum straight up if I have 4x 1070?
Airbrushkid
It's seems to be cheaper with out nicehash. Remember all there fees. I get that if you run ethereum from a pool there is no fee. So then it depends on where you got you wallet. Then there's the exchange.
Imhotep
I own 2 Fury X and 2 1080 Ti. Mining ETH + SIA Furies wipe the floor with the Ti's. Those of you guys having trouble watch youtube while the cards are mining should try dropping the intensity.
I don't know about nicehash , but Claymore miners have this option.
Archaea
Those Fury cards run sooooooo hot while mining. Even with a 20% undervolt - my radiator was too hot to hold your hand on, and just two of them would heat up my whole basement to the point it was slightly uncomfortable. I didn't mind very long on them because of the heat issue.
xrayos
sorry, to bump this thread back up.
but, can we discuss the profitability of the 1080ti vs 1070?
I've got a mix of 1070 x8 doing about 240MH/s (31MH/s each) mining ETH another rig of 8x 1060 getting ~200MH/s (25MH/s each).
now that the prices of the 1070 are above $400, I need to look at the 1080ti. Cheapest I can find them are about $650 each card. Now is this really worth it compared to the 1070/1060?
Archaea
mining profits have dropped low enough for me - I'm just staying put. Each 1080TI is only making about $2.50-$3.00 per day (before electricity) on NiceHash right now. If it comes back to profitability I'd buy more. I'm still running 65% power, at 95% performance. If you look at the nice hash profitability calculator - the 1080TI - runs 95-99% of what it proposes for hash rate at only 65% power with the overclock mentioned in the first post in this thread.
xrayos
^ what about using it to mine ETH at 37 MH/s? What's the power draw there?
For example my 1070 gets 31MH/s and uses only 100w at 50% tdp. I have memory o/c by +600.
xrayos
^ well I bit the bullet and bought one. It seems my 1070/1060 rigs are working fine. Now to dabble in something new. Are you guys using the 1080ti for zcash?
