Hello People
I am agonizing over my final HTPC build. I am debating between a AMD and Intel Build. Here is what I have so fat.
This will mainly be to view Media (Blu-Rays, VOD, Video Streaming etc) on a 55' LCD TV. Gaming is secondary (I already have a dedicated PC for gaming so its not the primary role.
In my earlier post I originally was going to do encoding as a role, but its pointless as my i7 920 will be far better at it regardless. So I dropped this requirement.
I am looking for Performance (but not overkill) on a tight budget (500 EUROS), not power hungry and as quiet as possible.
Both Builds have a optional dedicated videocard that I may or may not add. That is secondary and will decide Later, but I do want the freedom to add it if I chose.
Also I am not sold on the case, the Silverstone Grandia are great but it might not fit in my cabinet, I might need to get a smaller one.
Finally 600W Power enough? Need More/Less. Remember assume that a VC might be added later so allow for that upgrade.
Micro-ATX INTEL CPU Based
Silverstone Grandia GD04B USB 3.0 (Black) 107.90
Asus P8H77-M 79.71
INTEL Core i3 3220 (3.3GHz) 100.50
G.Skill RipJaws RL DDR3-1600 CL9 8Go (4x2Go) 39.00
Crucial 64Go M4 61.90
Asus BC-1205PT (Black) 55.00
OCZ 600W ModXStream Pro 66.41
Gigabyte GeForce GTX 650 OC 1Go 94.53
TOTAL W/O Graphics Card 510.42
TOTAL 604.95
Micro-ATX AMD CPU Based
Asus F2A85-M LE 69.90
AMD A10-5700 - 3.4GHz (Socket FM2) 108.21
Sapphire HD7770 Vapor-X 1GB GDDR5 OC 104.41
TOTAL W/O Graphics Card 508.32
TOTAL 612.73
Asus P8H77-M 79.71
TOTAL 604.95
TOTAL 612.73
