Kaos said:Im looking for a CLI type program or command to encrypt an ntfs volume.
Anyone know of a command already present that would encrypt a drive/voume?
i figured encryption = security so ill drop the post here.
Cipher said:Removes data from available unused disk space on the entire volume. If this option is chosen, all other options are ignored. The directory specified can be anywhere in a local volume. If it is a mount point or points to a directory in another volume, the data on that volume will be removed.
