COD:4 CD Key Location
lessthanjakejohn
Hi I have COD:4 installed and now its kind of screwed up and I want to reinstall. Only problem is I can't find my cd and key. How can I retrieve the key from the already installed game?
Go to options > multiplayer options.
There should be a menu that lets you change your CD-key. In it, you should see the CD-key you're currently using.
If your cod4 wont start up then youll have to fire up your regedit. Im pretty sure its in a regestry somewhere if you serch for call of duty 4
