CM Glacer 240L Expandable Liquid CPU Cooler
Discussion in 'Overclocking & Cooling' started by HardOCP News, Feb 4, 2014.
  1. HardOCP News
    HardOCP News [H] News
    0
    Dec 31, 1969
    Want an all-in-one cooling solution that allows you to add components without voiding your warranty? Yes? Well then, be sure to check out this review of the CM Glacer 240L expandable liquid CPU cooler at Legit Reviews today.
  2. Betaboy1983
    Betaboy1983 [H]ard|Gawd
    1,264
    Dec 31, 2008
  3. cortexodus
    cortexodus [H]ard|Gawd
    1,614
    Feb 20, 2009
    That thing is hideous... I love it! :D
  4. doubletake
    doubletake Gawd
    560
    Apr 27, 2013
    I heard this was basically CoolerMaster's licensed/rebranded Swiftech H220. It sure looks like it.
    -Edit-
    Yeah durr, I just read the article :V
  5. Racheakt
    Racheakt [H]Lite
    122
    Apr 30, 2012
    it says "expandable" AIO
    do they sell graphics card kits that add on? how does that work?
  6. Heavygamer
    Heavygamer n00b
    1
    Feb 5, 2014
    I have spoken to a couple Cooler Master customer support staff members about expanding my Glacier 240L. On both occasions they were quick to point out opening it or expanding the loop voids the warranty.
  7. jhatfie
    jhatfie [H]ard|Gawd
    1,453
    Mar 19, 2003
    I have been running the Glacer 240L for over a month now with my OC'd 4770k. Love it thus far. I must note that the stock fans can get loud if using an aggressive fan profile. Mine is very quiet for normal use like gaming (my 780 Lightning is far louder), but with video encoding loading up all the cores to 100%, the noise is very noticeable once temps near 60C (again, my profile has fans at 75% at 60C). Pump is pretty quiet as well with just a light hum. Note that the Glacer does not come with a PWM splitter, which is sad since the H220 did.
  8. jmilcher
    jmilcher [H]ardness Supreme
    4,306
    Feb 3, 2008
    Use any block you want. This isn't a proprietary system...
  9. jmilcher
    4,306
    Feb 3, 2008
    Interesting. That was NOT the case with the Swiftech
  10. gigatexal
    gigatexal [H]ardness Supreme
    7,256
    Jun 22, 2004
    any word on finding a non skt 775 bracket?
