Nimisys was given the opportunity to present his case claiming I sent him a motherboard that didn't function. That thread served to Defame. Vilify, Slander, Demean, Belittle and generally trash my good name that I've worked hard for years to uphold and maintain with 213 successful transactions and zero problems with any member in that time. http://www.heatware.com/u/77136/to
In presenting my case here now I will provide the most compelling evidence to date that I would not, could not and did not send Nimisys a motherboard that was anything other than Working Perfectly, In Excellent, Undamaged Physical condition, Packaged with care and Priority Mailed to him.
I'll start with the very first quote in his thread "
Bought a used Asus Motherboard from Mothman on October 27th, paid via PayPal. Board was shipped that day. Board arrived in an Anti-Static Bag, in a different an OEM mobo box (for a different board, but not a real issue) packed with local papers within a Flat Rate box on October 29th. No shipping damage was noted, no obvious visual faults were seen with the board at that time. a PM was sent to Mothman to inform him the package arrived and looked good and that i would let him know how it went. So far nothing to complain about. "
"No shipping damage", "No obvious visual faults were seen with the board at that time", " Looked good"
It wasn't until NINE DAYS later that he reported 'A Problem" keep this in mind because it's during these nine days and the unknown conditions the board was subject to that I maintain the traces were damaged rendering the motherboard inoperative.
Now I will offer the most compelling evidence that what I present next is the only logical explanation for how the damage occurred.
https://i.imgur.com/tiIsaaF.jpg
https://i.imgur.com/yazGAWk.jpg
https://i.imgur.com/Tr7euvO.jpg
https://i.imgur.com/0a4I3Vg.jpg
I don't know how to directly link the images but the above is the documentation of my opening the board upon receipt from Nimisys and discovering the damaged traces. Notice how blatantly obvious these damaged traces are. I maintain that it would have been impossible for nimisys not to have noticed these
immediately during his initial inspection of the board, IF THEY INDEED WERE THERE AT THAT TIME ON OCTOBER 29.
After observing the damaged traces I informed Nimisys of this and that I was afraid to further test the board as I did not want to risk damaging my gear. Well after the thrashing I received in his thread I decided there was nothing left for me to loose and I have indeed re-installed the board in the original case with the original peripherals except for the i5-3470 I had to purchase for this test. This rig served me well for many weeks without issue.
I photo documented every step of the assembly and result of the test. I attached notes to the pictures with my observations and the process should be self explanatory. I'll link the photos and then give a brief synopsis of my findings: Also I included a couple pics of my current rig to show that I am indeed a competent, professional, meticulous builder of many fine PC's
https://i.imgur.com/Yc11kXy.jpg
https://i.imgur.com/CeMDUI6.jpg
https://i.imgur.com/S2ZILRv.jpg
https://i.imgur.com/gme95nf.jpg
https://i.imgur.com/TdiSnvB.jpg
https://i.imgur.com/eauMfKF.jpg
https://i.imgur.com/j9ynoPY.jpg
https://i.imgur.com/QmBkJvx.jpg
https://i.imgur.com/zEmhggk.jpg
https://i.imgur.com/1Aee3tX.jpg
https://i.imgur.com/n3kCJMp.jpg
https://i.imgur.com/9TZXxOe.jpg
https://i.imgur.com/qsnvpai.jpg
My most important finding was evidence of how the traces were damaged while in nimisys possession. As I have discovered over the years of building PC's,different ATX cases although spec'd the same, motherboards and I/O shields may not line up the same way and care must be taken not to force the motherboard into position with the I/O shield. In this case I found evidence that the I/O shield prongs were bent/aligned in a way that required just such a jamming and pushing force. Note that this force would have been applied directly over the location of the cases motherboard stand-off and the exact location of the damaged traces. When I initially installed the I/O shield and placed the motherboard down to slide it in it immediately hung up on those bent prongs, which are located right between the VGA and DVI outs and would have required that downward, jamming, pushing force to get the board under the prongs. I stopped immediately, noticing the alignment problem I properly adjusted the I/O shield prongs after which the motherboard slipped in effortlessly.
Now my final observation and conclusion: Based on the extent of the damaged traces and telling ninisys that those alone would cause the motherboard to not power up, this is exactly what happened when I attempted to power up the installed motherboard. Upon pressing the power button an audible click is heard and then nothing. This is a sure sign that the motherboard self diagnostic immediately found a dead short and I am certain could only be caused by the damaged traces.
