Cisco VPN vulnerability....bug worse than originally thought
Discussion in 'Networking & Security' started by Monkey34, Jan 31, 2018.
  1. Monkey34
    Monkey34 [H]ardness Supreme
    4,932
    Apr 11, 2003
    FYI:
    1. The exploit has now been seen in use in the field.
    2. The vulnerability is even worse than originally thought.....and there are NEW patches out to replace the ones they first released.
    Once exploited, the devices allow remote hackers to seize administrative control of networks and to monitor all traffic that passes through them.
    https://arstechnica.com/information...erability-cisco-dropped-is-now-under-exploit/
    DigitalGriffin likes this.
  2. heman22union
    heman22union n00bie
    42
    Nov 6, 2013
    Do you have an affected device? Have you tried any of the attacks against them yet? Do you know of a website that has details on how to execute the attack? Does the newest patch actually fix the problem? I'm looking to try it on my hardware so I can test it myself to make sure I'm protected. I have taken my ASA offline until I have enough time to work on it.
  3. Monkey34
    4,932
    Apr 11, 2003
    No, I don't have an affected device. Just passing along info to fellow [H]'s.
  4. dmolter
    dmolter Limp Gawd
    287
    Sep 30, 2009
    heman22union contact Cisco support directly. They are giving out the patch even if you do not have smartnet (paid support) on your the hardware. Keep in mind this only affects ASA firewalls with the webvpn service turned on and enabled on an interface
