archivalbackup
- Oct 12, 2007
I have someone that is looking to move their DHCP from a windows server to their Cisco Switches which is easy enough, however, they also want to retain a log of DHCP assignments so that they can track down who had what address at some point in the past if they need to (say RIAA letter or similar).
Configuring the DHCP is easy enough, and the DHCP Bindings Database appears to only hold the current address assignments, and does not archive the logs the way Windows Server DHCP does.
Is anyone familiar with a way to periodically archive all of the DHCP bindings off a Cisco IOS device acting as a DHCP server? Setting a debug level is not an acceptable solution.
I found a DHCP OID, but it is inaccessible
I think I would have to enable DHCP snooping for this OID to work, which is probably a good idea, but I would think there is a simpler solution.
Code:
http://tools.cisco.com/Support/SNMP/do/BrowseOID.do?local=en&translate=Translate&objectInput=1.3.6.1.4.1.9.9.380.1.4.1.1
