Protoform-X
- Jan 30, 2002
This router is replacing 3 other routers as the hub of a hub and spoke network.
One of the PTPs is working over IP 10.0.0.1. All traffic is passing on this interface without issue. The other two PTPs seem to be connecting, but not passing traffic.
We are able to ping from router to router over all 3 of the PTPs. A host on the A side can not ping a host on the Z side. From the Z location the VPN has picked up as the failover and I can ping the A location, however, the Z router cannot ping a host at the A location. The only thing that has changed is this router. Thoughts?
Code:
show run
Building configuration...
Current configuration : 5946 bytes
version 12.4
service timestamps debug datetime msec
service timestamps log datetime msec
no service password-encryption
hostname NPHC2800
boot-start-marker
boot-end-marker
card type t1 0 1
card type t1 0 3
logging buffered 51200 warnings
enable secret 5 $1$oXKf$0c5x2HJoxaKbIHBhF80QS0
no aaa new-model
no network-clock-participate wic 1
no network-clock-participate wic 3
--More-- ip cef
no ip domain lookup
ip domain name yourdomain.com
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
voice-card 0
no dspfarm
--More-- !
crypto pki trustpoint TP-self-signed-3468020979
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-3468020979
revocation-check none
rsakeypair TP-self-signed-3468020979
crypto pki certificate chain TP-self-signed-3468020979
certificate self-signed 01
3082024F 308201B8 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
69666963 6174652D 33343638 30323039 3739301E 170D3039 30333139 30303030
30395A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D33 34363830
32303937 3930819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
8100B1CA 45A6A6B6 EF9464DD D136C9CB C2321316 BDE7EB67 E2EC4269 BE30BD17
EBC45A99 1D04DAD2 6B0DDDA1 C58923BB 6555EA3E 8D3F8001 FF0DC0EF 66EE0704
07D47DB1 32280031 8098D167 7A6F3970 17DBD03F 4178AB50 24FD0B5A 881282AE
2504BF98 BE315F46 52F92C5A F3FE05C0 AA381CFC 98B20A6E 2AE715E1 6E47BCB0
81730203 010001A3 77307530 0F060355 1D130101 FF040530 030101FF 30220603
551D1104 1B301982 174E5048 43323830 302E796F 7572646F 6D61696E 2E636F6D
301F0603 551D2304 18301680 149EAE66 C94D13FB 09061048 3B66F18E 3BAEC97A
--More-- 2D301D06 03551D0E 04160414 9EAE66C9 4D13FB09 0610483B 66F18E3B AEC97A2D
300D0609 2A864886 F70D0101 04050003 81810033 95B41A7C 0D03C715 D11D8D82
99F38427 6A1F7321 364E643F 3F01E2C0 CF291AD6 271819DF 0D151B7C 57EE2CDC
3677DA9E 945F92BA 1869BAFF 0A15BB3C 59028188 B073C52D 64C33DF1 385338FA
EC2CAA4C 3585EED5 0B8C1C1B E4007B7B E9EFAE36 81958251 2862C761 A62798F7
3E588C39 01408DBD F941EED6 8782D8DE 5DD1BF
quit
controller T1 0/1/0
framing esf
linecode b8zs
cablelength long 0db
channel-group 0 timeslots 1-24
controller T1 0/1/1
framing esf
linecode b8zs
controller T1 0/3/0
--More-- framing esf
linecode b8zs
controller T1 0/3/1
framing esf
linecode b8zs
interface GigabitEthernet0/0
description Main Connection at 2nd Street
ip address 192.168.1.220 255.255.255.0
duplex auto
speed auto
interface GigabitEthernet0/1
--More-- no ip address
shutdown
duplex auto
speed auto
interface Serial0/1/0:0
description Connected to TATUM
ip address 10.0.1.1 255.255.255.252
encapsulation ppp
no ip route-cache cef
no ip route-cache
interface Serial0/1/1:0
description Connected to DVO
ip address 10.0.0.1 255.255.255.252
encapsulation ppp
no ip route-cache
interface Serial0/3/0:0
description Connection to PVO.
ip address 10.0.2.1 255.255.255.252
encapsulation ppp
--More-- !
interface Serial0/3/1:0
encapsulation ppp
no ip route-cache
router rip
version 2
network 10.0.0.0
network 192.168.1.0
no auto-summary
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 192.168.1.254
no ip http server
ip http access-class 23
ip http authentication local
no ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
--More-- !
access-list 23 permit 10.0.0.0 0.0.255.255
access-list 23 permit 192.168.0.0 0.0.255.255
access-list 23 permit any
control-plane
banner exec ^C
% Password expiration warning.
Cisco Router and Security Device Manager (SDM) is installed on this device and
--More-- it provides the default username "cisco" for one-time use. If you have already
used the username "cisco" to login to the router and your IOS image supports the
"one-time" user option, then this username has already expired. You will not be
able to login to the router with this username after you exit this session.
It is strongly suggested that you create a new username with a privilege level
of 15 using the following command.
username <myuser> privilege 15 secret 0 <mypassword>
Replace <myuser> and <mypassword> with the username and password you want to
use.
^C
banner login ^C
Cisco Router and Security Device Manager (SDM) is installed on this device.
This feature requires the one-time use of the username "cisco"
with the password "cisco". The default username and password have a privilege level of 15.
--More--
Please change these publicly known initial credentials using SDM or the IOS CLI.
Here are the Cisco IOS commands.
no username cisco
Replace <myuser> and <mypassword> with the username and password you want to use.
For more information about SDM please follow the instructions in the QUICK START
GUIDE for your router or go to http://www.cisco.com/go/sdm
^C
line con 0
password ********
login local
line aux 0
line vty 0 4
access-class 23 in
--More-- privilege level 15
password ******
login local
transport input telnet ssh
line vty 5 15
access-class 23 in
privilege level 15
login local
scheduler allocate 20000 1000
end
NPHC2800#
