Hi,
A couple quick questions for those of you with US Cisco ASA 5505 units.
1) If you put your ear up to or close to the power brick do you hear a whine? I've read of one other occurrence of this while searching the net. I'm curious if this is "normal" or not.
2) The female plug on your power brick... is it a 3 pin cloverleaf design or your standard 3 pin PC PSU design? Mine is a 3 pin cloverleaf.
Thanks.
Thanks.
