scharfshutze009
- May 22, 2010
No adapter included though because not needed Powered by POE (Power Over Ethernet) and ceiling mount. Originally Radio Should have only been disabled, but should be enable now. No POE injector, console cable aka rollover cable, or Ethernet cable included. Ceiling Mount Included, but not shown. IOS might not boot correctly because environment variable set incorrectly, which Cisco representative said not to set and when I tried to set it based on how you set it for a switch apparently I just made the problem worse. Therefore, I had to remove the environment variable because it wasn't right even if it does need set and leave it unset, so that it will boot partially correct to IOS to make it easier to set and net to recovery console where it's more difficult to set.
I hope you consider my price reasonable to because I need to sell and replace with a lower end model Cisco Aironet AP, but at least new open box lower end enterprise ap's cost about this much and that's all I feel comfortable buying on ebay because I've tried purchasing refurbished or used for low or ridiculously low prices. However, the used or refurbished AP had either a problem with the hardware or software and I went through a difficult enough time upgrading the IOS on this because the Cisco or other guides on the internet aren't completely accurate as to how to do this, which caused me to take months to restore IOS to this and have to get help from a Cisco representative. Also, most other listings or competative offers I found for this are on used or refurbished and I never used mine, but messed up the software when all I needed to do was enable the radio and probably should have just left it alone.
http://www.ebay.com/itm/232307122735?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1558.l2649
