Sniper|3d-R|
- Oct 30, 2000
I have comcast net connection that connects to a surfboard 5100b, which connects to a linksys router. From the router I have 2 cat-5 cables, One that connects to a desktop thats connected to the net, and another cat-5 cable that connects to my cisco 2950. I have my desktop and my lappy that connects to the 2950 via 2 more cat-5 cables.
Everything has been working great, up unitll last night. I just lost complete connectivity. The link light no longer turns on when its in port 1-24 as a uplink from the router. Yet I can take the same cable and plug it directly into my lappy and get full net access(what im doing now). I have changed nothing on the router. I have powered it on/off etc... I was actually playing a game, and then all of a sudden it was like someone pulled my cable..
Im working on a new config to see if that will change anything... But anyone else have any ideas? Im stumped here.
Below is version and running config info.
Running Config
Code:
CISCO2950#sh ver
Cisco Internetwork Operating System Software
IOS (tm) C2950 Software (C2950-I6Q4L2-M), Version 12.1(11)EA1, RELEASE SOFTWARE
(fc1)
Copyright (c) 1986-2002 by cisco Systems, Inc.
Compiled Wed 28-Aug-02 10:25 by antonino
Image text-base: 0x80010000, data-base: 0x80528000
ROM: Bootstrap program is CALHOUN boot loader
CISCO2950 uptime is 9 minutes
System returned to R
System image file is "flash:/c2950-i6q4l2-mz.121-11.EA1.bin"
cisco WS-C2950G-24-EI (RC32300) processor (revision E0) with 20402K bytes of mem
ory.
Processor board ID FHK0637Y1VU
Last reset from system-reset
Running Enhanced Image
24 FastEthernet/IEEE 802.3 interface(s)
2 Gigabit Ethernet/IEEE 802.3 interface(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:0A:F4:5A:4F:C0
Motherboard assembly number: 73-7280-05
Power supply part number: 34-0965-01
Motherboard serial number: FOC06360QDS
Power supply serial number: PHI06320CP2
Model revision number: E0
Motherboard revision number: A0
Model number: WS-C2950G-24-EI
System serial number: FHK0637Y1VU
Configuration register is 0xF
Running Config
Code:
CISCO2950#sh run
Building configuration...
Current configuration : 1607 bytes
version 12.1
no service pad
service timestamps debug uptime
service timestamps log uptime
no service password-encryption
hostname CISCO2950
enable secret 5 $1$ZYkM$oH9vvEMnFMaYsWqnRFaOc0
enable password pw
ip subnet-zero
spanning-tree extend system-id
interface FastEthernet0/1
no ip address
interface FastEthernet0/2
no ip address
interface FastEthernet0/3
no ip address
interface FastEthernet0/4
no ip address
interface FastEthernet0/5
no ip address
interface FastEthernet0/6
no ip address
interface FastEthernet0/7
no ip address
interface FastEthernet0/8
no ip address
interface FastEthernet0/9
no ip address
interface FastEthernet0/10
no ip address
interface FastEthernet0/11
no ip address
interface FastEthernet0/12
no ip address
interface FastEthernet0/13
no ip address
interface FastEthernet0/14
no ip address
interface FastEthernet0/15
no ip address
interface FastEthernet0/16
no ip address
interface FastEthernet0/17
no ip address
interface FastEthernet0/18
no ip address
interface FastEthernet0/19
no ip address
interface FastEthernet0/20
no ip address
interface FastEthernet0/21
no ip address
interface FastEthernet0/22
no ip address
interface FastEthernet0/23
no ip address
interface FastEthernet0/24
no ip address
interface GigabitEthernet0/1
no ip address
interface GigabitEthernet0/2
no ip address
interface Vlan1
ip address 192.168.0.110 255.255.255.0
no ip route-cache
ip http server
line con 0
line vty 0 4
password pw
login
line vty 5 15
password pw
login
end
