apopleptic
- Jun 6, 2013
Okay, so I had wired my house with cat6 and cat5e a while back and was running a simple network with just a FV220 dsl modem and an unmanaged 16 port gigabit switch.
Now the network has expanded and includes the unmanaged switch upstairs and a 3com 4200g in the basement set up as simply as I could make it.
I went to add an 1142n and went through the difficulty of making it stand alone and etc, and I had it working completely when it was upstairs connected directly to the modem. When I connect it to a switch, any of 3 switchs, it refuses to make a connection.
At first I thought it was my modem being a PITA, but I moved a Linksys e3200 (so I could better manage DHCP) after the modem and the same issue...
I also tried making a bypass for the POE injector so that there is a direct connection for the 2 pair for data being injected with the 48v, but exactly the same thing.
Before it is asked, the POE is being injected after the switch.
Error was something along the lines of negotiating DHCP.
Static IP had a similar hangup and no link, but I don't recall the error.
Any suggestions before I just make a big long home run of fresh cable? I don't want to do a home run if I don't have to since the console is coming from the server in the basement.
