Chromecast (1st gen) + cheapest way to 5.1
badcookies
hello [H]
after finally upgrading to a router that can actually stream plex+chromecast (old model), I am getting sick of 5.1 DTS/AC3 playing sound effects loud and voice tracks low. yes i know i can convert it all to aac what not but time is not my friend.
so i have a tv with three hdmi inputs.. i have a 2.1 speaker connected to my tv via 3.5mm. i have a bluray player and a ps3 and amazon firestick (only need but 2 minimum inputs, more is better but 2 is good) so I would like your advice...
whats the cheapest way to get 5.1? i know it probably involves a receiver but i dont know if its worth spending hundreds... im thinking all i /need/ is about 2 hdmi in, aux in and thats it. i do have this amp at my disposal: Amazon.com: Lepy LP-2024A+ Hi-Fi Audio Amplifier Stereo Power Amplifier Car Amplifier with Power Supply, 3A Power: Electronics
tl;dr: need advice on how to 5.1 chromecast+plex for cheap.
Saturn_V
Entry level AVRs w/ 3-4 HDMI ins can be had for as little as $150-200. But you have to buy speakers for that too. Start with three- Left Center Right for starters, they should acoustically match. (if not identical speakers- at least identical drivers.)
Save the surrounds and subwoofer for later. Wiring for rear speakers and positioning needs to be thought out.
There are cheap HTiB (home theatre in a box) systems too, but I'd only trust full components to perform the HDMI switching.
badcookies
i have the 2.1s and i also have two speakers that are speaker wire; maybe i can put that to use too (even if it means speaker-wire to rca)
where would i find such an entry level AVR?
also, i dont necessarily need hdmi switching. i dont mind physically swapping the input since i am looking for entry level.
is there something that will automatically convert 5.1 to three? just want video voice track to be equal to the sound effects.
Saturn_V
You'll want HDMI switching, it makes it easier since the newer surround formats (Dolby Digital Plus) only pass through HDMI.
As where to find a cheap AVR, I bought a couple through Woot. Newegg has a few too. The stereo companies change their models out every 12-18 months.
Vengance_01
just be aware using plex and chromecast will cause movies to transcode 5.1 i know it will not support dts just not sure about dd 5.1
