Wait until Black Friday, buy the best that's available at that time for the budget you have.
You can't really go wrong with either setup.
I have both, they seem comparable. I think 1080 wins in some games but Vega 64 in others. So pretty much a wash.From my limited research I believe 1080 is far superior to Vega 64.
I vote for Vega 56.
If the 1070ti is little faster than Vega 56, you're still better off with 56 as it has freesync.
Im spewing there isn't a Acer 38" with gysnc or that there isn't a Vega that is as fast as my 1080ti strix.
decision made easier for you with this sale?
http://promotions.newegg.com/NEemai...=am9uYXRoYW4udm9uZW5nZWxuQGtjLmZyYi5vcmc=#top
It even includes Destiny 2 which you can sell the code for an extra say $35-40 bucks.
Please forgive me if you already know this, I'm trying to understand your question.The prices of 1080 and Vega 64 are under $500 which brings it closer to 56 and 1070Ti price. So am thinking about those 2 atm.
Do u think freesync advantage will matter if i end up getting the 1080, or is 1080 strong enough to make sure no tearing occurs?
Thanks.
Good price, but don't count on selling the code, as it's likely tied to your Nvidia account that you will have to verify by having the drivers detect that you have the card in question installed.
If you go with the 1080, you won't be able to use Freesync, but you will be able to use Gsync, the Nvidia equivalent. Are you asking because you're already set on a Freesync monitor?
Non-adaptive refresh rate monitors refresh at their rated speed regardless of output from your video card. Gsync and Freesync are both adaptive refresh rate technologies.
Tearing occurs on non-adaptive refresh rate monitors when your card sends a new frame to your monitor while your monitor is in the middle of a vertical scan. Thus, one half of your monitor starts drawing the new frame while the other half is still displaying the previous frame. It'll happen whenever V-sync is disabled and isn't really related to the strength of your GPU.
V-sync is an option that tells your GPU when the monitor is about to start the next vertical scan. That way, your GPU can time the next frame so it gets sent to the monitor as a whole, and won't get "torn" by a desynchronization between your refresh rate and FPS. The downside to this is that sometimes your GPU has to wait for a vertical refresh to send the next frame to the monitor, which can create a perceivable "input lag": the game's response to your input will seem delayed because you won't see the results of that input until the monitor begins it's next vertical scan and the next frame is drawn.
With Freesync and Gsync, your monitor only refreshes when your graphics card sends it a new frame to draw. Thus, regardless of the framerate, you will see no tearing: your monitor doesn't get "interrupted" with a new frame mid-scan. This is also why most adaptive refresh rate monitors have higher maximum refresh rates. On a 144hz monitor, you can see up to 144fps. And lemme tell you, that makes for an AMAZING gaming experience.
If you have a 144hz Freesync monitor and an Nvidia card, the adaptive refresh rate portion won't work; AMD's Freesync module won't talk to Nvidia's GPU. You'll still enjoy the benefits of a high refresh rate panel, and be able to play games to 144fps, but you'll need to turn on Vsync to avoid tearing... and as noted before, that may create perceivable input lag.[/QUO
Given that you've settled on a Freesync monitor, I'd say go with Vega. You might not get the same performance as you would with the 1080, but it'll be close, and adaptive sync is awesome.ok Guys I've decided to go with Acer XR382CQK (it has freesync).
Now do u guys recommend $499 Sapphire Vega 64 or should I get MSI GeForce GTX 1080 with free (Destiny 2) for $469 after MIR.
Let me know what u guys think.
Thanks
Thanks
Since you bought a Freesync monitor it would be a shame not to use it to it's potential. That means buying the Vega 64 or 56 whichever one suits your budget best.
Powercolor $499 with the nice silver case (these are beautiful cards if that matters);ok Guys I've decided to go with Acer XR382CQK (it has freesync).
Thanks
https://www.newegg.com/Product/Prod...14131727&cm_re=Vega_64-_-14-131-727-_-Product
That is a good price, I have a Sapphire Vega 64 Liquid Addition and a 4K monitor and it does great with FreeSync. Your 38" with slightly lower resolution with FreeSync should work well. That is one hell of a nice monitor!
boxing is the worst I’ve ever seen. No foam, just cardboard. If the box hit the ground the card has minimal protection.I've had 2 PowerColor cards so far and they have been fine (though they are more of a budget brand than say MSI or Gigabyte).
Powercolor’s
Their website doesn’t work most of the time. Their telephone number is disconnected.
I’d steer clear unless the price is really good. The cards themselves should be the same. The only difference is the sticker on these reference cards - but the rest of it surrounding powercolor is so bad I won’t buy another powercolor.
Frankly. At the risk of sounding like I have a vendetta against AMD (I don’t). There is no way I could recommend a Vega right now compared to Nvidias offering. Freesync isn’t even reliable right yet. Opengl doesn’t work, games are buggy, clock speeds aren’t steady, web browsing with chrome is buggy(laggy). Simply put, Vega in current form is crap. I had three of the Vegas. I’ve sold two, and am fighting an RMA with the third one and will sell it after. The drivers are beta to this point.
I’m calling a spade a spade. Don’t buy one. You have been warned. The 1080ti experience - even without freesync, is just unbelievably more smooth than my Vega experience was. If you want AMD, buy a Fury X or wait six months until they fix the crappy Vega driver issues.
My friend bought a Vega. He sold it and went back to Fury X to avoid the hassles that exist with current drivers. I have thee local LAN party friends that bought Vega. All four of us have sold ours now. All had separate and yet similar issues on various monitors and PCs, games, and windows. All of us decided separately they are junk cards right now. We’ve been talking about our issues and frustrations through text messages. I realize that sample size is small, 4 people — but it’s 100% of the Vega owners I know in real life, and all four of us bought two Vega cards or more — so it’s not like we are speaking from just an unlucky sole card.
Do you want to play a game or crash to desktop repeatedly?
Do you want freesync in name only with random slowdowns to 10-30fps or do you want actually steady and reliable/even frame rates at 60hz?
I haven’t read any reviews on Vega that paralleled my and my friends terrible experiences, so I don’t know what to make of that. But when I put in my 1080ti all of those frustrations immediately dissapeared.
If I only had one machine, I would go with Nvidia and G-Sync, no question.
However, with FreeSync in the picture, it does make AMD look a little more viable.
At this point, that is one of the only real reasons to go with Vega: if you have (or are planning to buy) a FreeSync monitor, it seems like a waste to get an Nvidia card.
Glad someone else asked this, as I've also been wondering.
I want a card in the $350-$400 range, but I could go higher if I felt it was actually worth it. And I want to get the best bang-for-the-buck for non-gaming purposes (potential video editing in the future, playing with photoshop, etc)... because while I do game on a weekly basis I am fine gaming on low-graphics settings. I don't care how my games look so long as they play without excessive stutter, etc. Plan to run 2x 1440p monitors (one for work and one for distractions, b/c multitasking is a thing I do too much of).
Been leaning towards the Vega 56 but the 1070 is tempting, esp if prices drop when the Ti comes out.
XFX Vega 56 is $399 on Amazon.
https://www.amazon.com/XFX-Radeon-Graphic-Cards-RX-VEGMTBFX6/dp/B07532T488/
XFX Vega 64 is $499 on Amazon.
https://www.amazon.com/XFX-Radeon-Graphic-Cards-RX-VEGMTBFX6/dp/B074DK6NHQ/
XFXSupport is one of the nicest, most helpful manufacturer's support people on [H]ardocp.
First time vega has been available for MSRP right?
Call Amazon today. They have a pretty short price match window of only 7 days on items sold by Amazon.I missed the eBay deal for 429, so I paid 469 from Amazon earlier this week. Hopefully I can get a price match or credit. Could always buy another and return it.
