Chipset drivers for AMD based laptop
RCL0000ZK
Hello,
I want to install Win XP Pro SP3 32-bit on a HP DV5030US laptop.
I do not have the original CD (if any) that came with the laptop.
This is the driver download page of HP for this laptop.
I do not find the chipset drivers(the one which you have to install right after installing OS and before any drivers) in that page. So where do I get it form?
I have found the following pages for drivers. But I do not know which is the right one:
http://support.amd.com/us/gpudownlo...x?type=2.7&product=2.7.5.3.4.3.2&lang=English
http://support.amd.com/us/psearch/P...hipset+Motherboard&ostype=&keywords=&items=20
RCL0000ZK
The "Southbridge drivers" in the second link looks pretty old.
About the first link....That is the page that I get if I go to www.amd.com and select:
Code:
[U][B]Download Drivers[/B][/U]
Motherboard / Chipset
Windows XP Pro / Home
Radeon Xpress 200M
View Results
This is why I'm confused :(
Also, what are the GART Drivers for?
knothead34
no idea what gart drivers are.chipset drivers are not updated as fast as video drivers at least the way i understand it. radeon xpress 200 has been out a while. i would still try those and then check your device manager to see if any errors appear after you download them i bet you wont find any.
