hey guys, so like i said before: i got back from europe on wed night, got the parts thursday at work, and started that night. i was severely jet lagged all the way till about saturday so didnt take much pics just was trying to concentrate on the work. truth be told i didnt start having fun till saturday morning around 8am. so here is what i got. pics and descriptions team. the final build pics will come sometime this week when i get done switching and testing procs and get the temp sensors reading on the aquaero. then i'll tuck those last final cables away.
first pic i took. already got the rad up on top.
pic of my 2 lovely temp sensors. think i mentioned how i siliconed them in there. well thats where they will be, on the hot and cold sides of the radiator. wooo. also note well how the return line from the rad goes thru the neat lil hole i cut in the lian-li faceplate. yep, it runs down the back side of the drive cages.
got the mobo in, measuring loop runs and tube lengths etc.
here we have the niftie mounting posts for my storm block. this took a lotta work and searching at the hardware store. the main issue was got get the bolts on the other end of the backplate to sit flush, otherwise the mobo would bend up around the socket. But now the way it works is that some springs, washers and risers sit on the posts and i simply slide the STORM down then tighten with the thumbscrews. FTMFW
you might have noticed some of the mini sinks in the other pic, here is some more
Rotated the HDD rack, this will be its final placement.
This shot gives an idea where the return line of the tube form RAD -> RES will go.
Got the gfx cards in place and tubes cut and attached-
And now a few pics as the rest of the parts are placed and the loop filled and air bled. i began the leak test here
And thats it for now folks. will try to take some good pics with the proper camera. but its pretty for real now. will take detail shots of the important bits that i thought were either time consuming or special for the build.
