I've seen the fridge idea bashed time and time again, but I havent yet come across my idea for it. Typically what is suggested is placing a single radiator for a watercooler into a fridge. This is shot down because a fridge cannot cool a cpu putting out 100+ watts of heat. So here is my idea...
Rather than place a single radiator inside a fridge and feed it the heated water from the cpu -- use a two radiator setup; one outside the fridge and one inside the fridge.
The water coming from the cpu runs through the first radiator and is cooled to room temp.
The water from the first radiator is then fed into the fridge into a 2nd radiator. The water is chilled to any extent possible, and then fed back into the cpu. Preferably both radiators will be running fans.
In this scenario, the fridge is only working to cool ambient water.
Downsides? I can only think of the fridge having to run 24/7 operation, and the condensation issues that exist with everything else in this forum. Im sure you could find a fridge somewhere with a decent duty cycle; commercial unit or something. The key would be finding everything cheaper than a typical $800 phase change unit...
This could be used to cool either a cpu or a peltier I imagine.
Thoughts?
Yay 1st post!
Thoughts?
Yay 1st post!
