Cheapest Quiet Decent PWM 120mm Fans
Discussion in 'Overclocking & Cooling' started by legcramp, Feb 17, 2017.
  1. legcramp
    legcramp [H]ardForum Junkie
    10,580
    Aug 16, 2004
    What are your thoughts on the CHEAPEST, quiet, and decent fan? It doesn't have to blow a lot of air (probably around 40cfm).
    I built my HTPC and purchased a "PWM fan controller" to control 4 yate loons medium speed fans that I purchased almost a decade ago. I didn't read enough reviews and thought the controller would be able to control non-PWM fans but it does not.
    Thanks!
  2. pendragon1
    pendragon1 [H]ardness Supreme
    6,649
    Oct 7, 2000
    pick 2 of those and then hit the newegg search
  3. capt_cope
    capt_cope Limp Gawd
    462
    Apr 12, 2009
  4. Kryogen
    Kryogen Gawd
    937
    Feb 3, 2002
    seriously, you are asking for cheapest, quiet and decent in the same sentence.
    Quiet and decent wont be cheap
    cheap and quiet wont be decent
    cheap and decent wont be quiet
    if you want quiet and decent, buy noctua, it wont be cheap.
    Just my point of view.
    The-Tmann and Ocellaris like this.
  5. doyll
    doyll Kyle's Thermocouple is HOT
    877
    Feb 4, 2012
    Arctic F12 PWM are a decent low cost fan .. not the best but for about $5 each they are not bad.
  6. pendragon1
    6,649
    Oct 7, 2000
  7. legcramp
    10,580
    Aug 16, 2004
    Thanks doyll, those look like they'll fit the bill for the 5-pack @ $5 a pop.
    pendragon1, I don't think those are PWM fans though but thank you.
  8. Eric1285
    Eric1285 [H]ard|Gawd
    1,516
    Feb 10, 2003
    I'm running 4 of the Arctic F12 fans since they're what came with with the Liquid Freezer 240 I bought. They're not bad, but I'll be replacing them with Corsair ML120's soon - have had them sitting here for months, just too lazy to sleeve them.
