wilson0416
- May 8, 2013
Hi everyone, any idea? must without lagging
This would depend on the streaming software. On the linux side users can stream multiple HD streams from an ARM cpu. So you will have to be more specific.
What is k-lite codec pack?
Incredible hacker/pirate tool used for playing high quality anime, that has been obtained completely illegally from BD rips.
If he has NVidia card, he didn't activate CUVID properly, or he has conflict with MADVR.
My help ends here if OP is a pirate.
That was a tongue in cheek definition. I basically can't imagine a situation where network access would use 100Mb/s or 1Gb/s line and there would be problems with streaming. I seen however MASSIVE problems with video rendering.aw come on.... hacker tool?
being a pirate doesn't make somebody a hacker.
Cheapest = AMD
I recommend 4 cores minimum, 6 or 8 if you can splurge when it comes to Media serving. Again AMD has the cheapest 6-8 cores.
There is no BR to a movie Spirited Away I like, so until Amazon gets the BR I run the the Japanese 1080p HDTV Japanese Rip and stream it with the lossless video settings to my PS3. <3 it! This movie looks AMAZING in 1080p!
AMD Quad Core Llano @ 1.5GHZ-2.5GHZ speedstep can easily serve media files from my experience. But if downloading+uploading stuff, web browser 10+ tabs open or playing facebook games it will lag for this movie. So a 3GHz hex would be ideal if you want it to run in the background smoothly while actively using your pc/laptop imo. You can get by with 4gb ram, 8 better, 12 best for this kind of thing imo.
Hope that helps, Good Luck!
Thats like saying how far can you push a car if it runs or not.Cheapest processor that can stream 1080p movie with GPU or without GPU
