Cheaper Techsmith Camtasia Studio and Snagit
Discussion in 'General Software' started by rec0d3, Aug 1, 2017.
  1. rec0d3
    rec0d3 Limp Gawd
    166
    Jun 28, 2017
    Anyone have any alternatives? Like a reseller with WAY cheaper pricing than Techsmith? Crazy prices... Someone hallppppp!
  2. needmorecarnitine
    needmorecarnitine [H]ardness Supreme
    4,604
    Feb 10, 2004
    I used to use Snagit then I switched to Windows built in Snipping tool. What features specific to it do you need?
  3. rec0d3
    rec0d3 Limp Gawd
    166
    Jun 28, 2017
    Recording desktop mostly to do tutorials.
  4. zero2dash
    zero2dash [H]ardness Supreme
    6,065
    Oct 23, 2007
    You should be able to use OBS to do screen recording (ignoring the streaming functionality); if you have an NVIDIA graphics card (and the GeForce Experience app), you can use that to capture the desktop as well.
    Greenshot and ShareX are both freeware alternatives to SnagIt.
    muz_j likes this.
  5. odoe
    odoe Madministrator Staff Member
    10,199
    Oct 10, 2001
    I do vid tutorials too. I've tried lots of shit. On Windows, Camtasia has just been the best option I've found so far. More options on Mac for similar.
  6. rec0d3
    rec0d3 Limp Gawd
    166
    Jun 28, 2017
    So you use Techsmith with the crazy prices they have? :(
  7. odoe
    10,199
    Oct 10, 2001
    Yeah, but like I said, for Windows, I think it's about as good as you can get.
    Depending on how long you need it, you can get Adobe Premiere for $50/month using Creative Cloud.
    I've heard CamStudio is a good free alternative, but I found it was ok to record, but you still need editing software.
    Plus, depending on what you use it for, it's a tax write off, so there's that silver lining. I haven't seen other resellers of it. Sometimes there are coupons or sales.
  8. rec0d3
    rec0d3 Limp Gawd
    166
    Jun 28, 2017
    Eh, I hate the watermark.
  9. odoe
    10,199
    Oct 10, 2001
    On Camtasia? That's only with the trial, no water marks with a license.
  10. rec0d3
    rec0d3 Limp Gawd
    166
    Jun 28, 2017
    Right but I don't want to buy a license it's so expensive lol
  11. muz_j
    muz_j Limp Gawd
    161
    Jul 13, 2014
    What about NVidia Shadowplay ? - as mentioned by zero2dash ?
    I've used Shadowplay lots for recording games and also for recording desktop and applications too. It works great (assuming you've got a reasonable NVidia GPU). - requirements are discussed here - note the comments re: a GTX class GPU - https://forums.geforce.com/default/topic/975424/shadowplay-system-requirements/
    ...alternatively I've heard and read OBS is a good freeware solution too.
    https://obsproject.com
    ...that's 2 free solutions - both from zero2dash ... ?
