Santa Claus
- Nov 10, 2008
Hi, i have an old sparecomputer laying around, it has a small harddrive with xp installed and boots and runs fine so i want to put it to good use for backing up data and secondary storage for data i rarely use/need.
Its based on a nforce2(K7n2g-l) motherboard with a slighty overclocked amd32 T-bird 2400+ with 2x256mb ram and using builtin Gf4 graphics.
Would have 5 harddrives, one small for windows and a 30gb+160gb IDE but also 160gb+320gb SATA-II harddrives for a total capacity of 670Gb.
But the problem is the motherboard have no sata-ports so i need an addon controller for that, my needs are basicly just to access the sata-harddrives and raid/high performance is no requierment.
The data will be moved through a local area network at 100Mbps.
Its the first time im doing anything like this so wonder if its anything i need to think off or is it straight forward easy work?
Can i use any cheap modern pci-based sata-controllercard with this pci-slot?
Five 32-bit PCI bus slots (support 3.3v/5v PCI bus interface)
These cheap sata-controllercard only has Sata-I and the harddrives have Sata-II, are seagate harddrives known to have issues with Sata-I controllers?
Which of these 3 cards do you recommend?
Wintech SAK-15 SATA PCI Controller Card
- PCI Controller Card for SATA Hard Disks
- VIA6421 chipset
- Driver CD & SATA Cable included
- for Win98/SE/ME/2000/XP
- 2 x internal ports
- 1 x external port
SUNIX PCI-kort, Serial ATA-150, 2xSATA-kontakter(int)
2 Serial ata-150 ports, supports both raid 0 and raid 1.
Sunsway/ST Lab PCI SATA 2P eSATA/SATA, SiL3512
Serial Ata-150.
2 external and 2 internal sata-ports, only 2 can be used at the same time.
Processor Silicon Image SiI3512
Regards
- VIA6421 chipset
- 1 x external port
Serial Ata-150.
Regards
