Bense
- Aug 7, 2013
Bense's Fan thread:
This thread is for me to list some OEM part numbers for server/enterprise grade fans. Things such as an HP part numbers, Dell part numbers, etc shall be listed here, along with general dimensions, and amperage rating. In general, I am only interested in PWM controlled fans. However for unusually sized fans (whether 25x25mm or very large), I don't mind if it's 2-wire.
I am only interested in fans from manufacturers that provide flow charts for their fans that were generated using empirical, experimental data collected by mechanical engineers. Companies such as Delta, Nidec, etc.
If it's tan/brown and 'noctua' its overpriced, marketing hype, and it ain't shit to me.
My previous research entails much more powerful fans, however I need to find some that are in the 1.5-2.0A range.
PWM Fans can be controlled with something as simple as a $6 DC12v LED dimmer switch:
https://www.amazon.com/dp/B007V1B0W8/
I will start by posting a bulk of info here, and then later organize and corral my findings.
Some useful power adapters
* sata power plug -> dual 4-pin molex: https://www.newegg.com/Product/Product.aspx?Item=N82E16812226018
* 4-pin PWM fan splitter cable: https://www.newegg.com/Product/Product.aspx?Item=N82E16812200991
* 1 pwm header -> 5 fan splitter cable https://www.newegg.com/Product/Product.aspx?Item=N82E16812311001
Fans:
120x120x38mm - 3.30A - Nidec - J6165
V34809-35INT9F
WC236 (92x92mm)
Gateway E-9520T Server Fans 90500170714 Delta PFC1212DE
Fans:
V34809-35INT9F
WC236 (92x92mm)
