Cheap(ish)10Gb Ethernet for home network
Discussion in 'Networking & Security' started by SpeedyVV, Jan 12, 2020.
  1. SpeedyVV
    SpeedyVV [H]ardness Supreme
    4,215
    Sep 14, 2007
    Hi folks:
    What would you recommend for cost effective 10Gb ethernet switch and PC adaptors?
    Would be nice if there was a choice of 6 to 12 ports.
    Thanks
  2. IdiotInCharge
    IdiotInCharge [H]ardForum Junkie
    12,945
    Jun 13, 2003
    Look up Mikrotik switches (on Amazon) and Aquantia PCIe cards for 10Gbase-T using CAT6 or CAT6a.
    You can use 10G SFP+ NICs with direct attach cables (DACs) or short fiber runs with switches that have SFP+ ports, including from Mikrotik, and that may be a better option depending on what all you want to hook up at 10Gbit.
Tags:
