Changing motherboard to B360M PRO-VDH
im_shadows
My motherboard is coming and since it doesn't have wi-fi on it I'm gonna download everything such as BIOS and drivers before it comes, but what drivers do I really need?
There are these drivers on MSI's website:
-On-Board VGA Drivers:
Intel VGA Driver (?)
-LAN Drivers:
Realtek PCI-E Ethernet Drivers *
-Others Drivers:
Intel Management Engine Driver (?)
Intel Software Guard Extensions (?)
-On-Board Audio Drivers:
Realtek High Definition Audio Driver *
-System & Chipset Drivers:
Intel Chipset Driver (?)
-On-Board PIDE/SATA Drivers:
Intel Optane Memory (I don't have Intel Optane Memory)
What drivers do I need to install? I marked with a "*" the drivers I'll be installing and with an "(?)" the ones I don't know.
Mega6
You're going to get the most features and compatibility with the latest manufacturer drivers. They are bloated compared to a straight whql generic windows drivers assuming that is your OS. I usually install windows and see what needs to go in that is not found and go from there.
-> chipset - yes
-> VGA - if you do not have a discrete GPU - yes, but windows can usually install a generic vga just to install.
-> LAN - yes, better performance typically
-> Intel Management Eng. - yes, latest supported
-> Audio -> see what windows picks up, if u need fancy sound features - yes
-> SATA -> even though you may not have Optane, the manufacturer SATA typically has better performance. - yes
-> Intel Software Guard Extensions? SGX is for developers, i assume you are not so - NO
Short Story - install all but SGX, download everything and archive off to a NON-OS drive
Advanced Method - pick and choose what you need between generic windows and the manufacturer drivers. You will know what you need, update and put on the best. Comes with experience.
pendragon1
what he said ^ although I think the sata drivers are in the chipset pack if you dont need RST
