Change HTT voltage
patriot71
Is there a general rule for messing with the HTT voltage on an AMD64? I havnt read anything about this; every oc'ing guide I have seen never mentioned it. What about chipset voltage?
You probably can't change the HTT voltage as far as I know. My guess would be because it connects to so many different types of bus' on the motherboard you would have major issues if you jacked around with it's voltage. Probably frying the computer real quick.
chipset voltage goes up to 1.9v on my board if that would have anything to do with it.
i got a response on another forum that typically you dont need to mess with LDT & Chipset voltages on A64 mobos. I will play things by ear during overclocking.
