MrCaffeineX
- Aug 22, 2011
I have a Lenovo U510 that I am working on that has a 24GB SSD Cache drive. The chipset does not support using Intel RST, but rather Lenovo's solution was to use a 3rd-party software application to manage the caching. I was thinking that 24GB is almost enough space for me to squeeze Windows 7 (I downgraded the machine from 8), but I will need to relocate the various user, programdata, and program files directories to the HDD so that the SSD doesn't fill up.
By following this guide I was able to relocate the default locations for the Users and ProgramData directories. My plan is to completely install and update Windows 7 Professional 64-bit in a virtual machine and then follow this guide to sysprep the machine, capture the install image with ImageX, drop it on my Windows 7 USB install flash drive, and then run sysprep again using the unattended XML file created from the previous guide.
Is it possible to relocate the program files directories (default: C:\Program Files & C:\Program Files (x86) ) in the same manner (i.e. using additional options in the unattend.xml file)? In theory, this would give me the basic Windows installation on the SSD, but the directories that will take up the most space (Users, ProgramData, Program Files, Program Files (x86) ) will all be located on the HDD. However, I can't seem to find whether or not this can be done and/or which options will need to be included in the unattend.xml file. Most articles talk about doing it after Windows has been installed through a series of registry edits, which is a possibility, but it seems like it would be cleaner to do via the unattend.xml process during sysprep.
Any help and/or suggestions that you guys can make would be appreciated, though please kindly refrain from "Why on Earth would you want to do that?" or "That's just a stupid idea." posts. I'm bored and it sure beats going into work on my day off. Besides, isn't this how people spend their free time?
