Dark Ember
- Jul 30, 2001
So, I'm having a slight problem with this motherboard. I just hooked everything up last night. POSTs fine, installed/booted windows fine. However, It seemed to have set the multiplier on my mobile 2400+ to 6, with no way to change it in the BIOS. So, i have it running at 200 MHz FSB, so its at 6x200, at 1.2GHz at the moment.
If you have any ideas of a workaround or a solution or anything, that would help out a TON. I emailed Chaintech last night, but they haven't replied yet.
Thanks!
Thanks!
