...it is the first display that publicly supports Adaptive Sync and DP 1.2a+ but does not have an affiliation with either branded variable refresh rate technology. As it turns out though, that isn't bad news.
...The monitor supports DP 1.2a+ and Adaptive Sync which leads us too the fact that this monitor will work with AMD Radeon graphics cards and operate at a variable refresh rate. After talking with AMD's Robert Hallock at the show, he confirmed that AMD will not have a whitelist/blacklist policy for FreeSync displays and that as long as a monitor adheres to the standards of DP 1.2a+ then they will operate in the variable refresh rate window as defined by the display's EDID.
So, as described by the ASUS reps on hand, this panel will have a minimum refresh of around 40 Hz and a maximum of 120 Hz, leaving a sizeable window for variable refresh to work it's magic.
I'm curious how different this is than the over clocked Korean monitors. My overclocked one was still blurry at 120hz in fast moving scenes, which I assume is due to IPS.
Ya, I don't see how they are going to get past that. While 120Hz IPS certainly feels smoother, the motion clarity still leaves much to be desired.![]()
I'm not worried about it, especially since many of the gamers who criticize non-TN's pixel response times happily play with massive amounts of screen tearing on monitors with low PWM frequencies. AHVA/IPS/PLS haters can buy the PG278Q or BenQ equivalent. The matte coating is the main thing to worry about.
The FG2421 shows that not only TN panels are able to achieve near CRT motion. Hopefully this one will be able to also.
That is 100% because of strobing, though. Turn if off and it's as blurry as an ips.
The new high refresh ahva panel has some model with gsync (and therefore also strobing?) so that should be good.
This model just seems like asus trying to get a cut of the "overclock" ips market.
It could still be much better than the korea brands, since they have poor/no overdrive, and good overdrive matters much more than forcing a high refereshrate that the panel can't handle properly anyway.
Even so, in 2015, a model without gsync/freesync/strobing/other low persistence tech is just a budget offering, its not going to be anyones dream monitor.
The cheap Korean monitors have no overdrive at all as far as I know (or very little), the Tempest version may have some but it's not much (and it still performs decently).
I tried going back to a regular non strobed 60hz va panel and it was simply unbearable to me... the motion blur was just too much to handle.
For fps games and third person games it was extremely noticeable as there is motion going on 99% of the time.
For movies it was fine but once you go for near CRT motion 120hz you can't go back, at least for gaming.
Of course they have overdrive, they just don't have silly overshoot ghosting inducing overdrive controls or pointless overdrive settings which slow down the pixel response times like most of the name brand monitors. The Qnix/X-Star are pretty much the same as the Asus PB278Q (Trace Free 20; higher settings cause overshoot) and Samsung S27A850D (Response Time Off) while the MOTV/Overlord/Yamakasi (same monitor in different casings) are only slightly slower that the fastest AHVA/IPS/PLS, but are free from overshoot ghosting.
I've tested 3x S-IPS Korean monitors (overclock-able MOTV, Yamakasi and multi-input Crossover 2720MDP) which use the same panel and have identical pixel response times.
Pcper.com stated that the cost is around 600 dollars and shipping late Q1. Have anyone seen this monitor show up on pre-order pages anywhere?
Seeing how the Swift's release date was nowhere near what Asus stated I'd really doubt the Q1 release for this monitor.
You can see on the videos that it is "semi glossy" so that's better than a strong matte at least.
It appears there is little to no glow on the screen as well. Maybe the camera can't capture it, or maybe the AUO panels have solved it.
Does look like it has some IPS glow as you can see on the gun.... But this should still be the best PC monitor out this year and should last until OLED or better LCD screens come out anyway... It would be better if this was VA screen with ULMB and freesync but this will be the next best thing.
That's some nice pricing.
Now I'm torn if I should order xb270HU or wait for reviews to see if Asus has working overdrive
ASUS MG279Q Monitor Now Officially a FreeSync Monitor
http://www.pcper.com/news/Displays/ASUS-MG279Q-Monitor-Now-Officially-FreeSync-Monitor
FreeSync only can be activated within 35Hz ~ 90Hz.
