CCD MI-6: Performance in less than 7L
Discussion in 'Small Form Factor Systems' started by Firewolfy, Nov 23, 2015.
  1. leifeinar
    leifeinar Limp Gawd
    344
    Sep 24, 2007
    Sorry, forgot to mention the corsair sf600 platinium :)
    Need tho give it some thoughts, it quite expensive to get this imported to Norway. taxes , fees and so on.
    GermanDrifter97 likes this.
  2. GermanDrifter97
    GermanDrifter97 n00b
    43
    Jan 6, 2017
    I found the supplier for my cables over at cable-sleeving.com. From a quick glance it doesn't seem like there is a supplier mentioned for Norway. Maybe import fees from another country is cheaper? I don't really know. Also you could look if there are any private people who offer to make custom cables for your PSU. Maybe there is an ad on ebay or something similar.
  3. rfarmer
    rfarmer [H]ard|Gawd
    1,142
    May 9, 2014
    The sleeved cables included with the Platinum will be better than the flat cables included with the Gold, you will still have very long cables for the MI-6. I found custom cables just made things so much easier to build in the MI-6.
    GermanDrifter97 and Engr62 like this.
